RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 09-21-2006 | 09:33 PM
  #362
dragonpilot's Avatar
dragonpilot
My Feedback: (38)
Default RE: Nitro models pusher Bobcat?
ORIGINAL: bassman
I have already experienced the lack of glue on the landing gear blocks. This is the first time I have seen a two piece block. They did a great job of forming the wooden parts in the wing but then didn't put any glue on them. I had one block come loose so I opened up the wing and epoxied the parts in. On the other side I ran some CA down into the hole in the block. So far it has stayed together well. What did you replace the main gear wires with? Did you use a prefab landing gear or did you bend up new ones yourself. The nose gear is not a problem and is preforming well. It's just the main gear that seems very soft.
Bassman
Yah, the stock metal gear isn't too strong and bend easily and once bent, even easier. I made these for replacements. I may make a bunch of them if there is a market. Maybe paint them. One day, I'll go to retracts maybe.
