RCU Forums - View Single Post - Tach range: ST 90 ringed
Old 09-22-2006 | 08:20 AM
Flyer95
Default RE: Tach range: ST 90 ringed
The ST90 will not overheat if you use big props. It has bigger cooling head than most 90-sized engines. I run APC 16x8 @8400rpm on mine and use a quiet pipe to get the best performance at that rpm. I did not use the stock muffler more than i few tanks so I dont remember if it would overheat the engine on the oversized props?.
