RCU Forums - View Single Post - Evolution 46 Help
Old 09-22-2006 | 01:25 PM
opjose's Avatar
opjose
Default RE: Evolution 46 Help
Actually DO NOT "forget about it"...
If you do this the needle valve will turn with engine vibration as the engine warms up.
Instead remove the limiter and pull out the metal pin, then re-install it.
Before you do re-install it, also pull out the clip and bend down the clip arm a bit more to apply more pressure.
The limiter holds the clip in place so that is another reason to keep the blue aluminum limiter w/o the pin.
