ORIGINAL: icecreamslick
I replaced all of my white Tamiya connectors with Deans connectors, but if I ever need to send my electronics in for repair or replacement I would DEFINITELY install a new Tamiya plug first. [
] I don't know how strict they are, but if you alter the unit in any way I'm pretty sure that it does void the warranty. Make sure that the lead looks stock by soldering it to the terminal where the original lead was connected, rather than just replacing the end.
Jason
Thanks Icecreamslick. I'll probably do that. Do you know where they sell the same or better wire for this project? Tower has large gauge wire that may stress the DMD. I don't want to use that. what is the gauge of the tamiya wire anyway?
On another note, are the motors on the Leo 2 the same as the stock 540's found in other tamiya kits?
