RE: Zenoah engine problems
An airplane G26 is a different animal, with a different crankcase, won't fit on the scooter.....It's posssible the flywheel key is not there or maybe the keyway in the new flywheel is not in the right place...It will spark but if not in the right place...Maybe you could compare the new light flywheel with the older one to check location of the keyway...
