RCU Forums - View Single Post - Edit: report on Evolution .36
Old 09-23-2006 | 02:52 AM
DarZeelon's Avatar
DarZeelon
Default RE: Evolution .36 reassembly question
Mike, Tom,
This is exactly what this cut-out is for.
Some engines have a flat in their back-plate, so the uncut piston-skirt will have clearance.
On the rotating crank-web and the rear bearing, such a flat cannot be machined... so the cut-out must be in the piston skirt.
Many engines may have no such 'cut-out' in their original, small displacement version.
But when the manufacturer 'strokes' the engine to offer versions of increased displacement, the piston will have a cut-out at its front; or if there already was one, it will be larger for the stroked version.
This way, the piston can descend further down without hitting anything solid...
