RE: Help with break in!
120 deg? Wow! slowly start leaning out that hsn(clockwise) remember only small adjustments(quarter turn) then run for a few minutes.
Keep you temp meter handy and test after each run,It will warm up above 120 deg after you lean it out. 240-280deg is about the temp you want.
