RE: After Run Oil
I only use after run oil at the end of the season and my planes will be stored for a couple of months.I have never had a problem.
As for draining the tank,I allways drain the tank before I head home from the field. After the last flight of the day, I pinch the fuel line until the engine stalls to be sure all the fuel is burned then I drain the tank.
Steve
AMA 511248
