RCU Forums - View Single Post - Another HL Tiger question
Old 09-23-2006 | 10:21 PM
Harquebus's Avatar
Harquebus
Default RE: Another HL Tiger question
You shouldn't have to buy extra fluid, meaning that they usually include a bottle of smoke fluid with each HL tank. And you can actually turn the smoke unit off via a switch in the battery compartment.
If you decide that the smoke function is not something you care to use, please be sure to switch it off as it represents a noticeable drain on the main battery and otherwise running it dry or empty could cause some problems (unit could burn out).
-Harq
