RE: on board battery checker problems
When you see the lights on your Voltwatch jumping all over the place when you use your servos, it is giving you some valuable information; your wiring is to small or your switch has high impedance and you are getting excessive voltage drop when the servos are drawing their peak loads. If you monitored that same point with an oscilloscope, you will see big voltage drops for just a few millisecond as the servos are excited.
