RCU Forums - View Single Post - Field Box Schematic Needed
Old 09-24-2006 | 02:25 PM
NCIS
Default RE: Field Box Schematic Needed
mouthpiec,
You know what you want. Draw up some plans or just do like I did. I figured it out in my head, made a list of materials and went to the lumber yard. I made mine where the cradles can be used for 20 size planes all the way up to 30% giant scale. I made mine with three drawers. One is sectioned off into cubes for small parts and the other two are open for whatever tools you need in one and spare props, etc. in the other. I used a 1 1/2" dowel that I use as a handle. The bottom of the box is longer that the box so I could make a ventilated area for my 12v battery and power panel. The other end is big enough to hold a gallon fuel jug or can. There is a shelf that is about 5" down from the top of the boxes walls. I then divided this area in half length wise for my radio, starter, glow heater and cleaning bottle, etc. I carry the paper towels to the field in the cradles. Good Luck
Gibbs
