RCU Forums - View Single Post - Tach range: ST 90 ringed
Old 09-25-2006 | 07:47 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Tach range: ST 90 ringed
The Magnum 108 carb has a 11.5mm bore.
With the old style Magnum 91 spring steel bushing, it has a 9.5mm bore
The bore on the Super Tiger carb is 8.75mm but it has a flat sided narrow spray bar that makes it effectively larger.
If your Super Tiger 90 has a round sided spray bar, it is the carb for the 40, 45, 51 engines.
The only difference in the big and small Super Tiger carbs is the spray bar.
