RCU Forums - View Single Post - Hover help
Thread: Hover help
Old 09-27-2006 | 09:39 PM
Daniel Z's Avatar
Daniel Z
From: SantiagoReg Metropolitana, Providencia, CHILE
Default RE: Hover help
The wrong setup could make a 3d plane impossible to hover; you can use a 4 stroker to use a big prop, bigger props stabilize a lot the torque roll, set the CG a little aft, move it until you have trouble to land and the tail drops when you cut throtle ... use big throws and finally an adecuate plane: lowest wingloading, and not so short coupled with big moving surfaces
