Hi Gang,
I received another lemon RTF from TH today.
SECOND AND LAST BY FROM THEM!!
I was going to send it back but decided to go ahead and fix the things up.
1.I repaired the wing
2.I installed the servo in the wing they right way and glued it in as it was not glued.
3.I repaired the hole in the stab fin.
4.Now i'm making adjustments to the controls.
Heres where I ran into a problem.
I had good rudder throw to one side and very little to the right.
I adjusted the clevis as far as I can.
to get the rudder centered I had to remove the servo arm and place it back appx 20* off.
The rudder is working but I can't get enough throw.
Do I have to shop for a shorter rod?
Can I use one of the round servo disk that has all the holes?
And last question.
Will this harm the servo?
Appreciate any help,tips,suggestions,etc
