RCU Forums - View Single Post - Need help-Avistar servo problem
Old 01-14-2003 | 05:10 PM
Whirley Bird
Default Need help-Avistar servo problem
Originally posted by Flyfalcons
To get equal throws, you must set up the control so that the servo arm is perpendicular to the pushrod when the control is centered. As far as the control is not binding then it won't harm the servo, but if you can try to adjust the linkage to get the servo closer to perpendicular then you would be better off performance-wise. One thought would be to pull the servo out and install it facing the other direction - maybe this would allow you to better adjust the linkage.
I have it all setup now and have good equal throws.
Sometimes the bargains at TH aren't bargains at all.
WOW!!!
I put a lot into this RTF plane.
Wing is all fixed up and I just need to do some minor adjusting on the clevis on one side and it's ready to go.
Thanks for writing
