Originally posted by Crashem
Wow you have had really bad luck most people have nothing but good things to say about the AvisStar
BTW I wouldn't glue the airleron servo into the wing use small wood screws and a couple of pieces of lite ply glued to tthe wing remember to remove the covering to get a good wood to wood glue joint.
Hi Crashman.
No I didn't glue in the servo.
The servo was mounted and mounted backward in it's small wooden mount that goes between the wings.
It's the mount that was not glued.
The Avistar is not the problem.
It's the folkes who pride themself on quality work and push out very poor workmanship.
I was going to return it but decided repacking,waiting for them and getting a refund ,etc I decided to redo most of the plane.
I'm still working on it.
I have a problem with the nose wheel.
Turns nice both ways but when the linkage is hooked up it's binding to the right and limits the rudder throw so for now it's not connected to the servo.
I'm putting a picture of it here later.
20 minutes from the box to flying
But looking real good now
