RE: Engine For CMP Spit
ok i will, but y should i need a check valve if the air/fuel mix is ment to be constant and controlled the whole time, if it needs a check valve dosnt this mean the ECU is not doing its job?? or not?
It would wanna be better than a standard 160FX cos it was nearly double the Price.
Nic
