RCU Forums - View Single Post - Scale antennas
Old 09-30-2006 | 09:40 PM
Campy's Avatar
Campy
Default RE: Scale antennas
Depending on the size of your F4U there are a couple of options you may want to consider for concealing the antenna.
1. Install a soda straw inside the fuselage and route the antenna through that to the outside
OR
2. Use a Hayes 18" loaded antenna with the soda straw inside the fuselage.
I use the Hayes on several of my scale planes with good results. Range checks show about a 10' loss of range between the Hayes and a full length antenna.
