beginner needs help!
I recently purchased my first (used) gas plane off of Ebay. It is a Hanger 9. I have played with the electric ones and thought it was time to move up. The plane came with a charger which was the wrong one. I have since aquired one. I charged everything up and started the plane yesterday. It seems to run fine. Here is the problem, when I turn the plane on all the servos work back and forth on their own. ( Rudder, aelirons, and throttle all work back and forth) I checked the crystal in the plane and it is a 36 and the radio is a 37. I thought this may be the problem. I took a matched set out of one of my electric planes. It still does the same thing. Does anyone have any ideas what may be causing this? Needless to say it can't be flown this way. When I started it I just left the plane turned off and controlled the throttle manually. Also is this a good plane for a beginner to learn with? Thanks for any advice given
Randy
