RCU Forums - View Single Post - In flight CA hinge failure...
Old 10-02-2006 | 01:35 PM
aerowoof
Default RE: In flight CA hinge failure...
I will never use ca hinges,used them once did not like the way they flexed compared to dubro or klett pinned hinges.I have airplanes that are over 30 years old still flying with the original pinned hinges intalled and no failures or loose hinges.I do check them as part of pre flight each time to make sure,just as on full size aircraft
