RCU Forums - View Single Post - In flight CA hinge failure...
Old 10-02-2006 | 03:21 PM
tychoc's Avatar
tychoc
Default RE: In flight CA hinge failure...
ORIGINAL: MinnFlyer
You said you cut the slots with a Slot Machine - That's good
You said you drilled a wicking hole - also good...
The question that comes to my mind is: Did you have the rudder flexed MORE THAN IT WOULD TRAVEL IN FLIGHT before adding the CA?
I find that this type of failure is almost always caused by this. You can't just flex the surface a little (either in hopes of keeping a small gap or any other reason), it MUST be flexed farther than the servo will move it or this type of failure is almost sure to happen.
At this point I don't know if I did flex it appropriately. This certainly is a possible reason for the failure. Due to the strong cross wind, I had the rudder on high rates while taxing on the runway and several times I had to give full rudder to turn the darn thing around.
I certainly will remember to check for this in the future
-tychoc
