RCU Forums - View Single Post - Another Brillelli Masterpiece - Briggs 34cc Four Stroke
Old 10-02-2006 | 07:40 PM
jtisch's Avatar
jtisch
Default RE: Another Brillelli Masterpiece - Briggs 34cc Four Stroke
Well, I have my backplate mounts made up, and drilled out my test stand for the engine and then mounted it (the 40cc), then went to go look for a prop. To my chagrin I found that all the suitable props I had already reamed out to fit my Tartans (1/2 in.dia. hole). So I will get some more props and give it a try soon. I plan to start out with stock muffler, carb, magneto ignition(except for the shaved down flywheel) and than go from there.
J
