RE: HD BatShare
Yes, it would be like this: switch to BatShare to 4800 mah Fromeco Peerless Li-ion battery to input of Fromeco regulator, output (6.0v) of regulator to receiver and repeated for the other side. The plane is a 35% Aeroworks Quick Build 260 with 7 8611a servos. Yes, I know I have way to much battery but I already have them and used them this past season! I know from measuring the battery voltage that one battery pretty much powers the plane - that's why the idea of a BatShare but my Fromecos have Deans connectors on them and the BatShares that I had were regular JR-type conn3ctors. On the next plane I will use 2400 mah Fromecos and I will use the SuperRegular/Power Expander that I purchased from you a couple of weeks ago. So, my original questions: will the regular BatShare work if I replace the JR connectors with appropriate Dans connectors, and can I return the HD BatShare for you to upgrade it to two HD/Deans connnector outputs?
Bobby
