RCU Forums - View Single Post - soaking an engine
Old 10-03-2006 | 06:59 PM
proptop's Avatar
proptop
My Feedback: (8)
Default RE: soaking an engine
I've done it both ways...intact and dis-assembled.
If you don't want to take an engine apart, I would suggest a light, pre-bath scrubbing or brush off before soaking, to lessen the chance of grit getting into the engine, unless it's only varnish.
The way I look at it is that antifreeze is designed for all different types of metals, and most types of hoses and gaskets, and I would think most o-rings or whatever is in/on a model engine.
It won't hurt if a little gets left inside, but why do that when you can just rinse it out with fuel, or denatured alcohol, or gummout, etc. and oil well...
Then if I'm doing it for myself, I'll mount it on my test stand and run it for awhile just to hear what it sounds like, then use after-run oil.
ORIGINAL: ryan_m
Question about the anti-freeze soak method... can you just drop the whole engine in there, or do you need to disassemble it first?
I have a couple of 4 stroke engines that need cleaning. They aren't gummed up to the point of not turning over, they will turn, but there is thickish fuel (still liquid) in the carb area and lots of varnish on the outside of the engine/muffler. I would like them to look better and cleaner. I believe they will run as is, but wouldn't mind cleaning up a bit to hopefully make them run better.
I also have several old - OLD - os engines that sat in storage for the last 30 years that are completely gummed up.
I am hoping to take the lazy way out and just drop the whole engine in, but wanted to ask whether or not this would be wise...
