Some how I think choking the cylinder to death will not work
I have ordered a carb. There is not enough room for a velocity stack or to get anything in there to cover the hole; and because of its location and the way the nose was built I couldn't cut a hole in the side if I wanted to (which I don't). Using my starter on that flat prop hub is probably out also.
