RE: NEED HELP WITH ENGINE
what i ment was the idle screw. i broke in the motor as per factory directions. this motor is mouted upsidedown on a hanger 9 pulse. the problem is that if i try to lower the idle below 3000 rpm, it stops. as i said before i put teflon on the srew that controls the low.
