RCU Forums - View Single Post - Baffling the BME 110
Thread
10-06-2006 | 09:39 AM
39
rmh
Dec 2001
12,630
, UT
RE: Baffling the BME 110
You have to contain the inlet air - the flow intensity will depend on outlet low pressure setup.
the setup I used here - is held to motor box with four #2 skt head screws -comes off in a minute -but has never unintentionally loosened
If you want to glue stuff into cowl - use clear silicone rubber on cleaned glass surface - make little angles in any plates at their bases to provide good support. epoxy or goo can cause dimpling which will show on outside of cowl.
Reply
Like
rmh
View Public Profile
Send a private message to rmh
Find More Posts by rmh
View iTrader Profile
