RCU Forums - View Single Post - Pro2K (sort of) Servo/Batt questions
Old 01-16-2003 | 04:15 PM
Paul_Barsamian's Avatar
Paul_Barsamian
Default Pro2K (sort of) Servo/Batt questions
Update:
Pulled all linkages, cleaned, re-oiled (triflow is absolutely the nuts as far as lube goes) and reassembled with the linkages snug but not too tight. Replaced the 9202 on collective, (talked to a bunch of people and the consensus is that 90oz/in is a good minimum for torque on a 60 sized collective system, the 9202 only had 72oz/in). Cycled the batt, and viola!!! Suddenly the batts are OK. Once I realized I had the engine too lean and riched it up a full half turn to begin tuning in again, I could actually hover and fly it around.
Morals of the story
Use a servo that has enough torque for the application.
Make sure all linkages are smooth even if the heli has been flown and especially if it has been sitting around for a while.
Use something to watch voltage (and implicit current) activity on the electrical system in flight, too much of a drop on a fresh new pack indicates a problem with one of the components, replace one by one until it works.
