RCU Forums - View Single Post - Avistar assembly question
Old 10-08-2006 | 12:01 PM
raideron's Avatar
raideron
Default RE: Avistar assembly question
Hey Pete... IMO, your right on the hinges, and ite the way I installed mine... I installed my
ails as the book said althe way up against the T.E..... And it has worked fine and help up
to the test of time.... But... If I had to do it over, I would leave a very fine gap...
The CA will "stick" the two together somewhat.. But as your done CA'ing all, you need to flex
the ails and it should be no problems... You need to get the slots/area cleaned and flat.. I
also drilled a little hole in the center of the slots to get more CA down in there... Key... You
need enough CA..... But not too much so as to get the hinge to brittle... Good luck..
