RCU Forums - View Single Post - Eflite speed 400 beep codes
Old 10-08-2006 | 01:06 PM
Deadeye's Avatar
Deadeye
Default Eflite speed 400 beep codes
Hey guys, I set up a Formosa for a friend. He wanted it identical to mine. It has an Eflite speed 400 motor, and a 11.1 volt lipo. It got away from him on the maiden flight, and destroyed the airframe. Radio checks out, but I'm getting nowhere with the motor. Instead of the initial beep when you first plug in the battery, followed by two beeps in succesion; I'm getting just a constant beep every second or two. I've tried every combonation of the three wires to no avail. This thing hit hard when it crashed, and am wondering if the motor is screwed? I should add that every time it beeps, the motor shaft turns slightly. I can't find anything on this motor's beep codes. Thanks for the help.
