RCU Forums - View Single Post - help please
Thread: help please
Old 10-08-2006 | 02:30 PM
ksoc's Avatar
ksoc
Default RE: help please
I am assuming you have the right stick set up for the gun elevation (Vertical / UP and DOWN). The trim tab the goes with the Vertical stick should have beenset to Neutral while you set up your tank.
To fire the MG, FIRST move the Trim Tab all the way up, THEN Move the Vertical Stick all the way up. The MG should fire for as long as you have the stick up.
To fire the Main Gun, FIRST move the Trim Tab all the way down, THEN QUICKLY FLICK the stick all the way down. The main gun should fire, and then "reload" before you can shoot again (apporx. 9 sec for a Heavy Tank)
If this doesn't work, you should go through the set up again. making all the trim tabs are set per the instructions (Neutral I think).
Good luck
Kevin O'C
<S.C.A.T.>
