RE: Eflite speed 400 beep codes
I'm assuming that the EFlite Speed 400 you're referring to is brushless. The motor doesn't beep, the ESC does. I think you ought to try it with another ESC. It could be damaged from the crash. Beep codes will be in the instructions for the ESC.
