RCU Forums - View Single Post - Eflite speed 400 beep codes
Old 10-08-2006 | 05:31 PM
Gary Hoorn's Avatar
Gary Hoorn
Default RE: Eflite speed 400 beep codes
The beeps you should be hearing come from the motor windings as the pulses are sent from the ESC. It sounds like something is damaged perhaps in the ESC itself. You did not mention how it got away from your friend but it could also be a radio problem. Do the servos work? Check and make sure the throttle trim is set properly and the that the channel is set correctly for the ESC.
Gary
