Originally posted by scottandpamela
Well, if my bathroom scale is accurate at all, the loaded weight of the Sig Field Boss with all my crap (fuel, starter, battery, power panel, etc.) and about 1/8 gallon of fuel is 31 pounds. With a full fuel jug, the total weight would probably be 38 lbs (since water is 8.5 lbs per gallon) - pretty heavy but not too bad - Good workout.
.WHEW!!!!!
Thats what I call a real weekender flight box.
You must have all the heavy duty items in there.
Well like ya said it will keep you in shape and you'll have everything at your finger tips
Hey BTW.
I searched the TH catalog both the small and the thick catalog.
I can't fin't that DU-BRO cap and fitting setup you have.
I guess i'll go with that red fuel container and the squeeze bulb.
