ORIGINAL: JR16
runs like a good ol chevy pick up??? 90% of chevy pickups are on the road the other 10% made it home
anyway i was gunna get a nexstar but i wanted to build a kit so i got a great planes pt-40.
P.S. get a Dodge
I had a Goldberg Eagle quite a few years back. I got the kit fully complete, up to the covering but I never finished it. Instead, it got consigned because of an eviction and I had to move to another state. But, the ones I saw flew great. The PT-40 is among those which are similar to the Eagle, so I'm sure it will perform very well. Kit building has the advantage of oversight, you get to check every joint and part as it's assembled.
And on with the subject: It's good to have a prop wrench, that way you can check to make sure the prop is tight enough before first starting the engine. Besides that, I purchased a glow stick, fuel, a fuel pump, a volt meter, and a field charger.
NorfolkSouthern
