RCU Forums - View Single Post - Subs? How?
Thread: Subs? How?
Old 10-09-2006 | 12:40 AM
barnstormerboats's Avatar
barnstormerboats
Default RE: Subs? How?
Also, As you get into the static diving subs, there are two different ways to do this. Either a gas system (like Propel) that uses a can of compressed gas that can be used to clear water from a ballast tank with an opening at the bottom and a valve that lets the air out up top. And a closed tank with a piston that moves water in and out to change the ballast level.
Pros and cons to both systems, but you can get a sub set up with either system.
[email protected]
