RE: Can't take off!
check your pitch linkage rods. What pitch are you at at zero throtlle in normal mode with trim all the way down. should be 0-3 degrees. no more no less. also check pitch angles in idle-up with throttle in mid-position. disconnect tail & main rotors before you do this......report back.
