E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Can't take off!
Old 10-09-2006 | 01:23 PM
Default Can't take off!
Heya fellas. I fired up the ol' CP yesterday. And with no throttle trim, I only skidded around a little bit. I used to always fly wit trim. But now I'm not so sure about it. Is it necessary to get the bird in the air? I'm happy though, I've had great control over her, until I maxed the throttle, and the trim. Erm, that ended in disaster. I'm gonna give her a pre-flight exam a little later today, and try again. Any tips?
Old 10-09-2006 | 03:40 PM
X3n0's Avatar
Default RE: Can't take off!
check your pitch linkage rods. What pitch are you at at zero throtlle in normal mode with trim all the way down. should be 0-3 degrees. no more no less. also check pitch angles in idle-up with throttle in mid-position. disconnect tail & main rotors before you do this......report back.
Old 10-09-2006 | 03:55 PM
I did all that, before, and after that, it wouldn't take off. Is it possible tail and main motors are reversed?
Old 10-09-2006 | 04:04 PM
lwatson's Avatar
If this was flying before, how could the wires get reversed? Was this re-assembled and is your battery OK?
I set my throttle trim to half way.
Old 10-09-2006 | 04:07 PM
ORIGINAL: charcoaldabs
If your main motor was reversed you would not be light on the skids....infact you would be pushing down into the ground
If your tail motor was reversed you would be spinning OUT OF CONTROL. Your tail motor would be additional rotation force WITH your torque instead of against your torque and thus you would be spinning like nothing else.
Old 10-09-2006 | 04:27 PM
X3n0's Avatar
dis-connect motors and then fire up CP. Move throttle up to the stops. Does the swash plate move up smoothly or is it binding ?????if you blades are not changing pitch with throttle increase that might be your problem !
Old 10-09-2006 | 06:18 PM
Jent,
I meant switched the plugs, not the polarity. I'm not THAT stupid, but I'm stupid enough to plug it into the wrong place.
Old 10-09-2006 | 06:55 PM
Jent,
Humm I suppose it is possible. I would expect the main motor to go very slowly if that was the case. And the tail motor to be extreamly fast. Plus the tail would increase in speed a lot faster than the main rotor. The main motor should be pluged into the lower port while the tail should be plugged into the top port.
