ORIGINAL: charcoaldabs
Jent,
I meant switched the plugs, not the polarity. I'm not THAT stupid, but I'm stupid enough to plug it into the wrong place.
Humm I suppose it is possible. I would expect the main motor to go very slowly if that was the case. And the tail motor to be extreamly fast. Plus the tail would increase in speed a lot faster than the main rotor. The main motor should be pluged into the lower port while the tail should be plugged into the top port.
