RE: Avistar assembly question
I found one extra hinge hiding behind a piece of cardboard in the box. I cut a new slit directly in the middle of the elevator and in the fuse under the rudder. Put in the hinge the right way this time, and it's much stronger.
Question about the engine. I am using an OS .46AX in this. The holes on the engine mount are further apart than the holes on the engine itself. I'm not quite sure how it's supposed to go in this way. Can anyone offer some advice? I looked all over the instructions, but there's nothing clear saying how it's done. Just says attach the engine with the supplied hardware. Attached a pic to help explain better. I can't imagine you're just supposed to sandwich the engine between the two brackets.
Thanks in advance.
