RCU Forums - View Single Post - Prob installing Bandit pipe
Old 10-10-2006 | 07:21 AM
pilott34
Default RE: Prob installing Bandit pipe
Here is a pic of what I have come up with so far...
I just put 2 basswood blocks just inside the aft lip so I can screw it much like Harly's. My next problem is that the outer pipe won't fit through the tailcone. Looks like Im going to have to trim the tailcone back by about 2" to make the hole bigger. I put a line of tape around the cone where I would have to cut it (see pic).
HARLY: Did you say to remove the aluminum retainer?? (see second pic) Also, you mentioned this would have been easier if I had the proper pipe...Do they even make a different pipe for the classic vs the super?
ID:	538366   Click image for larger version
ID:	538367   Click image for larger version
