Hi,
i ordered a Twist 3D and it will be deliverred tomorrow. My Saito FA-72 engine is impatiently waiting to thrust the twist. I've read some twist thread's in rcuniverse and thought that it would be the best if I start to mount the saito engine first before I install the rudder servos in the tail. Maybe I have a chance to see that the CG will become right? Some guys fit a saito FA-82 in this plane and they had to done alot of modifications on front of the fuselage. I don't want to dremel to mutch and plan to set the saito a bit away from the firewall that I don't run in trouble with the thrust linkage. Hope this will not affect the CG to mutch.
What does it mean when they say "When you in 3D mode" in the Aerobatics instructions. Did they mean a Dual Rate setup of the transiever with different elevator rates ? I train basic 3D flight with a Robbe FX-18 and the Aerofly Professional Deluxe simulator and wonder me if I cannot do Blenders, Harriers with a Hype 3D modell. The simulator plane will not do the flat spin if i start the blender ? What's wrong with my setup?
sorry for dozens of questions.
Regards
Frank
