ORIGINAL: eugenefelisco
Michael Yosten.....You are the king of 3d. How can you roll the plane without dipping it? Is it the plane or your fingers? I watched it a couple of times you did it slow and you fast, it looks the same no dip at all. Is the Mobius same as the yak and edge in construction and performance? If I can ask you whats the set-up in this plane, if you will. Thanks.
Thanks for the kind words. The plane maintaining alt during the roll takes both a good plane and practice. Yes the Mobius is the same in construction but performance is different on these planes. As I talked earlier in this thread the Mobius does not like to tumble like full on 3D planes do. But it groves much better meaning that it goes were you point it does not wonder around at all even in wind. Here is video of me going over the setup on the plane. Go to the video in post #7.
http://www.rcgroups.com/forums/showthread.php?t=573038
