RCU Forums - View Single Post - Avistar assembly question
Old 10-12-2006 | 11:37 AM
  #67
bruce88123
Default RE: Avistar assembly question
ORIGINAL: Pete1burn
BTW, regarding setting up the throttle, hitting the throttle cutoff button overrides the trims I'm assuming to push the sleeve fully closed?
It will as long as you have left a little travel in the servo for it to do so. That is why you are doing the other part of the setup.
If you had set up the throttle with the idle trim all of the way "down" and the throttle at "idle" it might not close.
