RE: Avistar assembly question
Change to position on either the throttle control arm or on your servo arm. Experiment with the different holes until you find one that gives you full travel with the throttle. Also, you can change the position of the servo arm on the servo itself which will vary how much travel you will have. Play around with it a little bit and you should get the general idea of what needs to be changed.
Ken
