ORIGINAL: fadi81
yup I think I prefer that as well, but do you drill the mount?
This is my problem
I want to know how to create the holes in the engine mount without weakening it.
Think about this. In the unlikely event of a crash a mount SHOULD break and protect the crankshaft. Smacking Mother Earth with a durable mount will also dent the piston sleeve with the piston. A glass mount is designed to be a bit fragile.
I've flown several planes of .40 size with nothing more than self-tapping 1" hex head screws threaded into undersize drilled holes, then backed out and Locktited. It's actually easier to visually check them as being tight. A missing nut is hard to see in an enclosed cowl.
The fellers here who don't lose mount fasteners may be the type who carefully balance their props, too.
