RE: Composite ARF canopy/hatch
This can be done but must be done properly to avoid a canopy coming off. The loads on these size canopies in flight is surprisingly high so any gaps/slop will eventually see them depart!
If you must make the canopy quickly removable then you can fit some locating pins in the front of the canopy that fit snugly into holes in ply support pieces glued into the fuselage. Use 2 QUALITY hatch latches at the lower rear corners on the canopy frame. Again, ensure the holes that the latch pin slide into are snug. You will probably also need a couple of ply tongues at mid points along the sides of the frames to stop any knife edge like forces pushing the canopy sideways across the fuselage.
Ultimately, the best solution is to stick with the factory method of 4 bolts (takes me less than 30sec to remove canopy as std) and isecurity is virtually guaranteed!
Rgds,
Mark
