RCU Forums - View Single Post - 24 Inch Prop Convert To Three Blade
Old 02-06-2002 | 04:02 PM
deputydog
Default props
Rule of thumb is you drop 1 size in diameter and increase one in pitch. There usually are no odd sizes in large props so you would go to a 22 x 12. variable pitch is ok! Try R & D for wood props that are on a metal hub, each prop is seperate. Or Desert Aircraft for Carbon like Meijlik.
