RE: Air Filter
Air filter oil is sticker and does not restrict the airflow like other oils. Why not be safe and use the proper oil? You can all ways use motorcycle air filter oil that is made for foam filters. It’s your engine so it is all up to you but I know the only stuff I will use on mine. Good Luck.
