RE: Avistar assembly question
Not sure if you have flown before, But if it's a typical Avistar, the tailend hangs
down a bit... By bending your "mains" up or using a smaller wheel in frt. so that
the wing is at least level to the ground, it can help on no bounce landings...
You have to feel safer with you changing out your hinges... Good luck on your flight!!
